TA perf diff cover install, Any tips?
jarredsoon
I was thinking of getting a whole new rear end but am putting it off until next year. I was just pickin up some oil and saw a TA diff cover so I grabbed it. Any tips for install on this baby? Is it better to use the supplied gasket or red rtv? Also what do I torque the bearing cap bolts to after machining them?
TIA
Jarred
quality piece i put mine on last summer, i used a grinder to do the flattening of the bearing caps, it did a great job
I used the gasket and red rtv I believe. I put the rtv on and let it set till it wasnt sticky and then let it on for 2 hours and then filled it up
Of course, every time I do something I break something cause I'm such an awesome home mechanic. My first mistake was collecting the diff oil into a catch can without having a container to transfer it into. Now my shop stinks like crazy!!!
Next I checked my firebird manual and found that the main bearing bolts torque to 55 so ya I go ahead and do that and break a bolt!! Are these factory bolts single use??
I finally got it out
I'm gonna order the bearing stud kit from TA performance and not break anything I hope......
55 is WAY WAY WAY WAY too tight.
The rear cover bolts are 14 foot pounds. The bearing caps are 5.
I used blue rtv and the gasket. I let it sit overnight.
