kymmee
Silver Member
Monitor your oil pressure with the gauge on the dash. Know what your baseline is and watch for any changes. Should be high when the car is cold and come down a bit when warmed up. Oil pressure is higher at throttle than idle. Since you are having work done-invest in a scanmaster, then you get real time readings and it is a great tool for monitoring your car.
I'm no expert at mechanical stuff, but I always glance at my gauges and scanmaster when driving. I know what the cars readings were when I bought it, and like I said that is your baseline. Any potential problems that are soon to arise, I would think you would have some changes in your dash gauges or scanmaster readings.
Personally, I wouldnt change or replace things that are functioning correctly. If it aint broke, dont fix it.
Hope this helps.
Hope this helps.
