michbc3
It's very easy to crack these Buick timing cover castings when torque'ing down the upper bolt that supports the crankshaft sensor bracket. I've cracked two covers so far; and of course this is a costly and time consuming mistake.
The shop manual calls for 22 lb-ft on this fastener which I believe is way too much. I'm going to use a nutdriver with "wrist torque" on this particular bolt from now on. The factory torque spec might be ok to use on the longer bolts where the casting is stronger, so I'll probably continue to use more torque on those.
I'd like to caution others about this.
Best, Bob
Best, Bob
