Trans cooler line routing
dklumpp
What is the correct routing for the cooler lines. I don't have any in the car so need to Fab them just don't know how they rout to the radiator ie: driver's side, over/under cradle, etc. Any pictures would be helpful as well. Thanks!
CLassicTube.com have them reproduced and are 100% correct, I got the stainless steel set on mine. Here's pictures of the lines (not they are bent for shipping) … I'll post pictures of the routing once I find pictures I took of mine after the ss lines where installed.
The route behind the flywheel cover to the driver side then along the oil pan to the front over to the radiator.PICT0004.JPG
during install (not I rebuild engine at the time so put lines in first then dropped down the engine before re-installing my transmisson
And some wider shots that will help
Thanks so much! I checked with inline and they didn't make any so glad that classic does! Im thinking I'll get the standard lines instead of stainless as I just ran the stainless fuel lines this weekend and was a big pain! Also, I just installed the engine and transmission so hopefully I can get the lines in!
