Hey everyone, a just discovered this forum the other day. The Turbo Trans am is what inspired me to do this swap and I thought I'd share with you my progress so far. let me know what you think, and any suggestions! thanks.
The car started out as a 2.8L sports coupe. I started with a bare 3.8L 109 block pulled from a olds cutlass. I purchased all the parts i needed and had Klots performance machine in Cambridge Ontario do the machine work, block is bored 30 over with speed pro hyperutectic pistons and has a compression ratio of 7.1:1. The heads are stock GN units that have been cleaned up. Cam is a comp cams set up spec'd at 215/215. Headers are cheap offshore knock offs from ebay. I'll get nicer ones when I can afford better. The turbo is a Turbonetics TE63 with a oil filter reloctation kit. The downpipe is a stock GN pipe that I modified to fit. The rest of the exhaust is a 2,3/4" dynomax cat back system. I used A 700R4 tranny with an adaptor plate from Jegs.
I still have a few things to get installed like some 42# injectors, ESC module, the proper MAF (thinking about the LS1 with translator), and some other minor things.
