turn signal switch / cam cancel
TTA 1077
[FONT='Verdana','sans-serif']Need a CORRECT part # for the turn signal/cam cancel and associated harness. Finally tracked down my steering wheel radio pad issues. It was a bad spring in the pogo post contact, but I cracked the circuit board trying to examine it. :censor: Can't find the Part # for switch and cam cancel with steering wheel radio control (UK3) option. Need to get this back together before Friday, last show of the season is on Saturday, HELP![/FONT]
My understanding is they been discontinued years ago and there's no aftermarket replacement offered.
If I remember correct Ozpont looked into this and might have found something that do work or even had some GM NOS ones ... see if you can ask him to help out or if he (Dave) reads this he can chime in
Out of production :jaw: What about all the Bonneville’s, GP's and 6000's that used them? Also that has been a common option for years, My '94 formula had them and even my GXP has radio controls on the wheel! Someone has to be making it. As I said, I found several aftermarket and even AC Delco ones, but none with the proper wiring and post connectors for the steering wheel controls. What do they expect us to do? What if my turn signals went bad and the radio controls were working fine? Would I have to give up using my radio controls to fix the turn signals? That’s absurd! This is the problem With GM, everything is disposable
