Rodimus_Prime
is the fill hole on the rear diff cover? There's like a rubber thing on the cover I thought it was supposed to be somewhere along the top of the diff?
Yea I added the gm posi stuff first then it took about 2 qts or so of the 75w90, good thing is everything looked great in there, pretty much like new, no metal bits, shavings, or teeth missing, old oil smelled terrible and sort of baby shit green.
When I first got the car I was told there was some leaking from the diff cover but I never addressed it. There was barely over a quart that came out into the drain pan. While I'm sure thats a problem I still have the issue at highway speed where the entire drivetrain feels like its vibrating. I'm not sure if its wheels out of balance, or wheel bearings, I'm running out of stuff to replace.
This was also my first good look under the rear of the car, good lord the stock suspension pieces are junk. Thin ass U shaped control arms and that piece that goes from side to side over top the axle.
You bought a car and didn't check the fluids? First thing you do when you get a new car...
Fluid smelled because it probably was burned...goodluck with that rear!
On both sides of the gasket or just one with the RTV?
As far as that cover, what are those two big bolts in the middle for, do they bolt to something on the gears inside or something?
That TA performance piece says it comes with a gasket, if i use blue RTV along with that where should I apply it to?
