Just curious as to what people have planned, I for 1 will be rebuilding the Tranny in the spring as it's slipping pretty good from 1st to 2nd, 63,000 and never touched, now pushing 21psi ... only a matter of time !!! 8)
I have a big project im working on. It all started with a blown headgasket . I took the heads off an seen that i burnt a piston pretty bad. :shock: So im going all out. should have a 10 sec car after the winter
Posted Sun Oct 29, 2006 8:11 pm:
I think I might try tackeling quite a bit this winter, but how much I'll actually get done I dunno. Between what I'm working on now and what I plan on doing the list is as follows:
Adjustable tubular LCAs and Panard Bar
Triple A-pillar pod with Vac/Boost, tranny temp and undecided on the 3rd
Subframe connectors
Eibach Pro-kit lowering springs (got a used set for cheap so I'm gunna try them out)
Of course some more cleaning
