alky
robert lee
trying to find the best way to rig this coolant tank, it would be nice to piggyback on top of the batt, with a way to remove it easily, the other way in the pics it seems to be in the way of everything, also not sure if it needs to be at a lower level to work right, any ideas?
yeah, not a lot of choices, i thought about taking the washer jug out, since its never driven in the rain ttarider
If you took the washer jug out, you would have to run a longer hose to it.
By the way I noticed Jason had his mounted somewhere to the right of the radiator. I supposed there are other places than mine, but I like the way mine sets in the metal brackets.
but he took either the air box or charcoal canister out , since i have the maf translator there, may not be a good idea
Might be alittle cooler if you put it in washerbox location since it wouldn't be right next to the turbo?
Get it figured out so I can copy it when I get mine!!!
Mines like the 3rd picture, kinda just loosley floating along side the radiator end tank. I find the less stuff that is permamnent the better as it seems my engine is always coming out over the winter.
I originally had it mounted with Julio's supplied zip tie like straps, but after pressurizing the cooling system with combustion gases it expanded that tank and broke both of them.:eek:
guess thats why they have such big tanks, closed system, lot of pressure:bomb:
Here ya go, one tie-strap to the maf hole, left the hose a little long to support the other end, out of the way now :yes:
Put it to the front side of your battery handle and it will sit still. Thats how mine is and havent had a problem with it. I have the same optima battery, so i know exactly how it fits. Steve Kiminski installed mine so i trust it will be ok over a long time.
I also just used a longer hose and tucked it underneath the air filter area on the driver side. Can't even see it. Been working just fine there. I didn't like the idea of it being above the battery in case the hose or tank leaks.
