Well I had just bought a new stock chip from eric at turbo tweak I hadn't installed it yet. I had a thrasher chip in there. I put the new chip in and it fired right up.
another thumbs up for eric:thumbup:
I'll answer this too. There is no better chip than the turbotweak chip. I have used ATR pitbulls, Thrashers, Kenne Bell, Red Armstrongs, Extenders, and besides the Extender chip none of them even compare. I have used Eric since he developed the chip years ago and always have had great service.What do you think of that turbo tweak chip? My car came with an after market chip. I'm not sure what the chip is, or if its doing any good.
I was going to ask if you had a Thrasher chip in the car because the problem sounds like what happens when the chip goes into anti-theft mode. Basically the car will run on the fuel in the rails and then die. If the chip had the anti-theft function on it you have to follow the proper procedure to start it. But in addition if the car has been sitting (which you said it had) the voltage will drop when starting. A little drawback to the anti-theft feature is that during starting if the voltage drops below 10 volts (which is still enough to start) the chip goes into anti-theft. I used to remedy this problem with a trickle charger for those winter months.
Should I get just the chip, or the injectors as well?
What are your plans for the car? 60 lb. injectors are a great upgrade but if you never plan on modifying then I would leave it alone.
I think I will leave the car stock for a long. With moding the 25th, and building a house funds are short. So just the chip then?
