I added a deep trans pan and it hangs down pretty low. I was able to shim the rear trans mount up about 1-1/2" and still have plenty of room in the transmission tunnel. The drive shaft is in the middle of my driveshaft loop, so no concerns there other than the front U-joint angle (is there an angle range?). It helped alot with clearance, but the pan is still directly in the line of fire if I were to hit something. Do the Hrpartsnstuff engine mounts raise the engine at all? I want to keep the pan due to the cooling and extra fluid capacity. Raising the front of the engine would help out alot.
