White Dwarf 89
Ok so I'm going thru small details on this new car of mine and found a leak at the bottom two bolts of the TH down pipe. Looks like they used bolts that were too long for the application because they bottomed out! I hope they did not crack the exhaust side turbo housing. Anyway, other than the right length bolts, will I need a gasket? It didn't have one installed and it may be the best way to install but could a copper gasket hold up under all the heat ?? Thanks in advance for any thoughts. Jr.
http://emob133.photobucket.com/albums/q74/Jackolivas/1303698316.jpg
