Drag Radial?
I'll get one when I get home from work around 4pm central time. Raining here so don't have the car w me at the moment. Otherwise this is the best I have.
Here these are better have to upload from the photo stream apparently...
Has a single 3' exhaust on it now. Luckily the factory tips were in the trunk so it will be back to the factory look soon.image.jpg
Exciting! What turbo you going w? Car looks good! I'm in the process of replacing my RazorAlky kit. I should have it all in by tomorrow! Mine was 6yrs old lol, apparently those pumps are only good for two yrs before they need to get rebuilt. Figured I just update it all buying new kit from Julio.
It's a billet 6266. Thank you for the compliment. It was on Alki but we have really good E85 here locally so it's getting converted. I've got new guages, flex plate and converter, turbo, injectors, fuel pump, downpipe, and now tires to try and put on this car. I just need the time.
I currently have a 6262 on her from my last build but this one now being fully built and stroked I want to go w the 6766 next yr. I have the pump and injectors to support it along w the Alky. Had to take away a lot of fuel in the chip w the #80 injectors and dual pump
Sweet! I'm building a girdled motor now for my Ttype. Just got a 6766 for it. Hope the factory crank does ok for awhile
295/50/R16 Mickey Thompson drag radials on mine, and they barely rubbed on the inside of the wheel wells on hard turns. Had to make sure the rear end was perfectly centered with the adjustable panhard bar, and had to tap in the wheel wells a little with a hammer. You can't tell that it was pushed in even knowing about it. Been getting consistent 1.51 60'times every day since launching at 18-20 psi off of the foot brake. With my 26" Hoosier DOT radials was getting 1.48 60' times launching at 10 psi, but wouldn't hook any higher than that.
