jarredsoon
Gold Member
OK so I am planning on driving my ass all the way to the reunion so I thought I had better clean up old TTA 733. It's leaking oil from the turbo drain tube so I bought a new gasket. I also ordered an rjc pcv valve for it too, hopefully that will last forever like they say it does.
I took the 61mm turbo off my other car and put it on this one over the winter and the car sure does go good!!! I decided I had better upgrade the fuel pump now that I have the bigger turbo, car already has a hot wire kit.
I ordered a racetronix fuel pump(walbro 340M), pulled the gas tank and put it in. All was well, fuel pressure was great! went to 68-9 psi on full boost, just what I needed.
Then the next day I drove the car downtown and parked all day, then drove home through traffic and two blocks from my house the fp guage goes crazy!!! up down up down up down then zero and car stalls. The car is still rolling so I threw it in nuetral and started it again, then kept driving and it did it again!! Only this time fp went to zero and car would not start. It died. in the middle of the street. So I walked home and got my jeep and towed it home. I checked all the fuses and connections they were all good.
I went onto the racetronix forum and they think it is a kink in the plumbing inside the tank. I put the pump in myself and the rubber hose that comes in the kit is wedged between pump and the metal fuel line so I dont think it could kink at all, plus there are clamps holding it. Plus it worked great for a whole day!?!?! This is not the first pump I have installed, I did my other car and it has been fine for years.
Does this sound like a typical walbro fuel pump failure??
I am gonna pull the tank AGAIN and look inside, this kinda thing makes me wish I had the "change fp in 10 min" mod. Has anyone done that? I think it would take just as long to cut a hole in my trunk floor as it would to pull the tank. I don't have many good tools so...
What do you guys/gals think?
